Brief Description: Riveted the rear spar assembly to the HS-801PP ski
Completed riveting right HS-702 to right HS-801PP. Sprayed zinc chromate primer inside the assembly covering the scratches from the bucking bar at Van's Builder Support's suggestion. Clecoed the rear spar assembly to both HS-801PP skinds and all attachment points. Riveted the rear spar assembly to both of the HS-801PP skins.
