Brief Description: Elevator - Trim wire harness alternate route
In order to safely route the wiring harness for the trim motor away from the trim motor jack screw, I drilled a 7/16" hole in the left elevator root rib, centered in the forward hole of the control horn. A rubber grommet will be installed in this hole to prevent wire chafing.
