Brief Description: Cont. Left wing and started Fuse
Finally rivited Wing tip to box end . The box Support which we make had to be taken appart because it pushed the tip of the wing end up to much to get the Wing tip installed into the pre drilled holes. We also finished the inboard rib support and cut the last two Cross tube covers which the fabric will be glude too. They needed to be trimmed down so the fabric would not be pulled up when it was layed across the bottom.
Started work on the Fuse. Rivited the seat supports and the upper bulkhead behind where the engine mounts. We also did the lower bulkhead support mod by cutting it off and lowering it 2 inches.
The vertical stabilizer was fitted into place and the upper rivits were drilled out to install the stabilizer extention at the rear. pictures to follow
