Getting the Rib inside in the correct possition and drilling the holes was a bit of a challenge, but it came out preaty good. We made good use of a hole finder. Also used the wing tip with a heavy grit sand paper taped to it to sand down the fittings for the possition lights. If all goes well the wing structure should be finished monday night. We will then move onto the Right wing This is day 8 since we got the Kit and have logged 52.5 hours so far. We have had to only remove two rivits so far that were put in prematurly.
