Drilled all holes for top ribs and installed all lower Ribs and clecoed bottom ribs for completion on Monday evening. We also cleaned up all the rib gussets to remove any sharp edges. Started in-board box end.
Top of in-board box end
Flat cover on bottom main ribs
Leading edge wrap with protective foil still on it
