Today we started off by finishing edges on all parts of the right flap. We then used a scotchbrite pad to roughen all edges and skin rivet lines where we will spray primer. Then we dimpled all parts L & R flaps using a combo of the C-Frame, air squeezer, hand squeezer, and the vice grip dimple squeezer. We then pulled the remaining wires in the wings...as follows:
--3 x 20 AWG wires in each wing. 1 nav, 1 strobe, and 1 wingtip landing light. --1 x 18 AWG wire for the stall warner.
I also cleaned and primed the end ribs of the flap that holds the reinforcement plates and brackets. Primed the plates and brackets as well.
Using scotchbrite pad to roughen up flanges for priming
Dimpling all parts using C-Frame, squeezer, and vice grip squeezer
Finished pulling all nav/strobe/landing light wires in wings
