Today I started off by dimpling the right aileron stiffeners. I then finished the edges on the right aileron skin, end ribs, and spar. I then used the hand squeezer to dimple the spar and some holes on the end ribs. Had to use the "vice grip dimpler" to get to the last 4 holes on the end ribs. I then primed all remaining parts left and right ailerons. Lastly, I back riveted all stiffeners to the L & R aileron skins using the rivet tape to hold the rivets in place.
Cleaned up shop.
More aileron work next session.
Used hand squeezer to dimple aileron spars and end ribs
