Today I started off by making the grounding wire for the stall warning assy. Cut a 3.5 inch wire, skinned each end, installed terminals, and attached the wire to the stall warning device per the plans. I then inserted a pull string and the required 18 AWG wire into the conduit...then ran conduit thru the left wing...tied up string and wire. I also inserted the 18 AWG wire thru the main spar, installed the terminal. Now it is ready to be hooked up to the stall warning assy. as soon as the LE assy gets riveted to the wing spar. Next I cleaned up the LE skins and inserted all ribs and installed clecos. Also clecoed in the joing plate on the end rib of each LE assy. Now both LE assy's are ready to be riveted together.
Next session I will cut out NACA vent on right wing as an extra vent and start riveting the LE assy's together.
Manufactured grounding wire for stall warn assy.
Installed conduit, pull string, and 18 AWG wire for stall device assy.
L & R LE Assy's cleaned and clecoed ready for rivets
