Today I started off by clecoing the flap braces to the left and right bottom wing skins...then match drilled them. I did the same for the Aileron braces on the top outboard skins. After deburring the newly match drilled holes, I dimpled the rest of the bottom skins. The only skins that I have left to dimple are the left and right top outboard skins. Next session I will finish that and finish the edges, deburr and dimple the flap and aileron support braces. I'll also prime the wing skin rivet lines on the inside of each skin.
Match drilling the left wing flap brace to lower skin
Match drilling left wing aileron brace to upper skin
