Today I started off by inserting the one missing screw into the right tank fuel sender. I then used the air squeezer to squeeze all right tank baffle rivets top and bottom. Cleaned proseal off of clecos. Cleaned shop. BOTH TANKS ARE SEALED AWAITING PRESSURE TEST. Need to do a final Ohm test on both fuel senders to make sure good contact with tank.
