Brief Description: Finished Riveting Inner Ribs Rt Wing Tank
Today I started off by unclecoing the right tank baffle. I then mixed up a batch of proseal and started riveting the top rib rivets for R2 and R6 as they were the only ones I did not complete yesterday. After bucking those rivets, I used the remaining proseal to seal all the rivet lines inside the wing....had to mix another small batch of proseal to complete this task. After cleaning up the inside of the wing tank, I re-clecoed the baffle onto the tank to let it set up and cure for a few days. Next my brother Andrew and I will seal and rivet the inner ribs on the left wing tank
