Today I started off by installing the inboard right tank rib onto the skin. I then measured and cut fuel aluminum tube to length, used flaring tool to flare end. Then measured and cut other end. Cut finger strainer off of brass nut. Will need to rough-up furl tube and proseal strainer onto tube. Also, had to manufacture small washer/spacer for blue elbow fitting in order to get antilock device to work properly.
