Brief Description: Rt Tank Fuel Cap Flange Rivets Drill Out & Deburri
Today I started off by drilling out 4 rivets on the right tank fuel cap flange and cleaned up the hole area with a Dremel Tool. I then deburred all holes both baffles....then finished up all edhes both tank baffles. Then I finished de-bluing one of the outboard bottom wing skins. I also deburred the baffle rivet holes on both wing tank skins.
Will need to re-rivet 4 holes on right tank flange
