Brief Description: Fuel Cap Flange. Fuel Strainer, Stiffeners
First of all we did some touch up work on the trap door for the right tank. It was not quite swinging on the hinge free enough so we cut the pin off with a dremmel tool, drilled out the hinge for the flapper door with a number 35 drill bit, and reinstalled. Works 4.0! Then we prosealed and riveted the left tank fuel strainer/drain, then the left tank fuel cap flange, and lastly the right tank stiffeners. We used the hand squeezer on as many rivets as we could on the strainer and the flange....then bucked the remaining ones. Then we cleaned up all tools.
