Brief Description: Match Drilled & Deburred Right Wing
Today I first went to Lowes and bought several 2x4's, angle aluminum, wheels/casters, and bolts/washers/nuts to built a wing stand per the Van's plans. After unloading all the supplies into the workshop, I started more work on the right wing. I match drilled all rib flange/spar holes per the plans. Dis-assembled the right wing and deburred both the main and rear wing spars. Did not have time to deburr the ribs. That will be on next build session.
