Brief Description: Assembled Rudder Frame & Match Drilled
Today's work was spent fitting all of the rudder frame parts together, clecoing the frame to the rudder skin, and match drilling all holes. Just a little extra work need to be done on some of the frame parts. Specifically, I had to Scotchbrite down a little bit more on the R-710 rudder horn to get a good fit. I also touched up a few edges with a piece of Scotchbrite pad. All holes were then match drilled. Now the rudder parts are ready for dimpling and priming.
