Ran into another problem with the exhaust pipes. The pipe from the left rear cylinder is bent too far and will not line up with the muffler. It is so bad that it appears the pipes will leak exhaust gases. The right side pipe lines up fine. The outlet end of this pipe is at least 1/4" from lining up with the pipe nipple welded to the muffler. I tried to move the muffler around to correct for this but could not make it work as moving the muffler affects the fit on the right side of the engine.
