There is no text manual instructions for the interior panels so the page reference numbers are in reference to the parts manual figures and parts lists.
I began with fitting station 2A closeouts, the middle console and flap cover. The first two items are aluminum and need to be fitting and mounting holes drilled. Station 2A close out also needed to have the hole for the fuel line from the header tank cut and the relief for the header tank cap enlarged.
The flap cover is a two piece molded plastic part. I'm not sure of the material but I assume they are made of PVC as the parts list calls out PVC cement for joining parts. The flap cover halfs are molded oversize with faint marks for cut lines molded in. Cut less than you think you need to remove and ease up on it removing material as needed get an acceptable fit.
