I finished the install of the Rieff preheater after the epoxy cured. Installed scat ducting on the cabin heat and carb airbox. I can't finish the inlet side to airbox until the engine cowling comes back from paint shop to be sure I have clearance for the filter.
I started to add coolant to the system and checking for leaks, none found but I seem to have air trapped somewhere as the system didn't take as much coolant as Rotax install manual states and I didn't find any information in the Rans manual on coolant capacity.
