Loctited the set screws in the throttle cable clamps, I had ran out of loctite. Installed the blue fuel tubing spacers on the throttle and choke cables at the firewall per the manual. Re-installed the oil lines after being sure they were dry after cleaning them with solvent. I started install of the Rieff preheater per the instructions. Finished installing fire sleeve on the fuel lines.
