Riveted pilot side interior trim strip in place. Did intial fitting of the window along the top tube and drilled and clecoed. I had found from doing on this the passenger side that the frame needed to be off the fuselage so you could clamp it in place.
Went back to trimming the passenger side window and lower door lexan along the center tube, finally happy with the fit.
Layout and drilling of the holes in the aluminum extrusion retaining strip. I will need to wait to drill the door using as a template when I can get some help from Pat to hold in place.
