Falcon XP Build Site (Claude)
Falcon XP
Installed Modified Nose Gear
Assembled and installed the modified nose gear in fuselage. Connected the stearing pedals and centering springs.
Modified Nose Gear Assembly Mounted. Forward is down and right.
Nose Gear upper assembly inside fuselage. Up is to right.
Closer view of nose gear assembly inside fuselage including steering connections and centering springs
Falcon XP Home
217
