I did not do anything before I went to work today. After dinner, I decided to begin final riveting on the interior ribs of the left tank. I set up everything and did 3 ribs. I'm getting a little faster working with the pro-seal. I added a bit more part 'B' (black stuff) to the pro-seal mix this time, because the previous session stuff is still very sticky.... This made the final product a bit darker. I'll see how well this sets up tomorrow. One tip I do have for other builders: When you apply the pro-seal and cleco the rib back on; re-use the same clecos on each rib for that session, since you are riveting only one rib at a time. There will be less clecos to clean at the end of the session. I also ran out of gloves and M.E.K. I will make a trip to Harbor Freight and Home Depot in the morning. 3 ribs down.....11 to go....this might take a little longer than I thought.
