I set up the chicken wire rack in the yard and began to move the elevator parts to the rack. I mixed the AKZO primer, because you have to let it sit for 30 before you can spray it. It was getting dark and cloudy out and I wanted to prime before it started to rain. Everything went according to schedule and I completed the priming in about an hour. I will be ready to do final assembly tomorrow (Saturday)
Elevator parts alodined and on the rack for priming. Note the spayer I use on the right.
The AKZO primer I am using needs to sit for 30 minutes after mixing part A to part B.
The parts dry in 5 minutes, so I brought them back in to the shop. Ready for final assembly
