Today I got a shippment of stuff from Stein...The fuel selector knob, the mini cabin lights and the box of plastice bushings were in the box. The fuel selector knob is alot nicer than the one that came with the valve. I still have to order the selection plate that will mount below the vavle (so you won't see the bolt heads. The big box of plastic bushings should be enough to finish the plane with. The small mini cabin lights are SMALL. I decided to mount these in the side bulkhead cover plates. In order to get access to the back of these, I decided to mount these lights on a round plate and then screw the plate to the cover plates. I can just remove the screws if I need to get these out. The side covers and the round plates will be painted just like the interior. I then drilled the cover plates to the spar/bulkhead, but will not rivet them in place until much later in the build. I would like to take credit for this mod, but I stole the Idea from Mike Shipper's RV-9A web site...Thanks Mike!
The light housing is in place. The light is in the center and attaches with screws
