Today I riveted the brake pedal assemblies and attached the master cylinders. I did not drill and connect the bottom of the master cylinders yet because I want to think about how I will line them up for final connections. I decided to go with the standard brake pedal and not opt for the after market cast aluminum pedal (with the R & V). I figured that's $100+ that can be better used on something else...
I also ordered the gear attached doublers from Van's. Tomorrow I plan to clean the shop. I will problably not work on the plane for the next few days....I have to get ready for the big thankgiving dinner....I'm cooking!!
Pedals are riveted
Assembly is set in plane....note the added springs on the master cylinders...
