Just messed around a bit today; paint for a trial run at painting the fuselage has not arrived yet, so things slowing down. Decided to try a polyurethane product.
Using a length of galvanized pipe the same diameter as the rudder pedals, I bent the brake pedal hinges as per plans. Lots of little adjustments to get them to bend freely.
Identified / marked the locations for the outer seat belt brackets.
General cleeanup of metal coupons for testing the new paint - should be here tomorrow.
