Fitted the fuel sender to the tank, I didnt like the sender that most people fit into the bottom of the tank. Put all the fittings in the tank and after cleaning it I left it pressurized overnight, so far so good. Made the fuel filler door again a little different to the plans. Reinstalled the engine control cables, hopefully for the last time. Had to move the voltage regulator a little as the bolts hit the fuel over flow tray. Next job is the windscreen.
