Nearly finished the wiring, need to drill some holes in the control sticks for the PTT button wires, once I have made my mind up which grips I will use, also just have to tidy up. Also have to calibrate the fuel gauge and wire it up. The fuel gauge is a Falcon type fitted into the top of the tank. Fitted the Mobile one antenna under the plane, just in front of the spar box. Headset jacks are fitted into a small encloseure behind the main bulkhead. I thought there was a problem with the radio when I first switched it on, I had a rubber ducky antenna pluged in and when I transmitted the MGL panel went crazy, after wiring the correct antenna things were fine. Extra hole in the panel was going to be for a compass but I found the compass wouldnt work because of the slope on the panel, I will have to find something else for this hole and fit a pedestal mount compass. Probably not a good idea having the compass off to one side anyway.
