Fitted the panel, didn't like the angle, decided more upright would be better and an edging would be better still. Didn't want to make a new Glare shield so I added 50mm strips. Took some time cutting and getting the angles correct, would probably been easier to make a new glare shield. Undecided but I will probably split the panel so the outsides are fixed and make the centre removable the same as the Corby. Getting the white plastic off the metal took ages
