Brief Description: FF3-2 Control Cable Blue Prop Gov cable (72.5 inch
Oct 24th 2011
Purchased the Venier Blue Prop Gov cable (72.5 inches) , Red Mixture (51.5 inches) cable and Black Throttle (47.5 inches) cable. I also include three Eye-Ball Bulkhead Fitting for securing the cables as they pass through the stainless steel Firewall Bulkhead. This allows for the steep angle from the firewall to under the frame of the Engine Stand. I needed to drill a 1 / 4 inch hole in the eye-balls and using a metal file enlarged to 5/16 inch for the cables to fit perfect. From then on the installation was quick and straight forward. Looks clean and should be easy to replace the engine control cables if need be.
Time 4 hours because I was working slow.
Also F.Y.I. => I have 1700 hours into the X-10 project at this point. In 3 years and 4 months. With about ~/ +/- 500 hours left to go.
Blue Prop Gov, Red Mixture and Black Throttle zEngien Control Cables with Eye-Ball Bulkhead Fittin
