Brief Description: SCAT tubing and Mufflers and Misc Stuff
Oct14th 2012
I completed anchoring the two mufflers with the hardware supplied with the Vetterman kit. Then I worked on installing the SCAT tubing for the heat system and routing and securing with Adel Clamps the spark plug wires. Also ordered and installed the final high pressure fuel hose that connects the Airflow main spider to the throttle body. And other misc items that are small and add up but must be accomplished before starting the engine next week.
