Brief Description: Clecoed the C-1002A-L/R Outside Door Shells and C
SECTION 45-04
July 4th 2010
Contined Sanding the edges of the Cabin Canopy until with-in tollarance of 1/16" to 1/8" of the C-1002B L/R Cabin Inter Shells with the new palm air sander I just purchased.
Step 1, Using the geometry method I located and drilled #40 the open rivet holes in the fuselage into the C-1002A-L/R Outside Door Shells and C-1002B L/R Cabin Inter Shells to the fuselage. Then I clecoed each of the holes. The door is temp secureed in place.
