Step 1, I final drilled #12 all the bolt holes in the WD-1006-L/R Rudder Pedals.
Step 2, Attached the Brake Pedal Subassembly in to the WD-1006-R Rudder Pedals using the hardware called out for in figure 1.
Step 3, Attached the four master cylinders into the WD-1006-R Rudder Pedals. Referred to figure 2 for orientation and hardware to be used.
Step 4, Added the eight AN822-4D Elbows to the master cylinders. Clocking slightly inward the four elbows at the bottom.
Step 5, Skip this as I am using custom made stainless steel brake lines and not the Van’s supplied plastic lines. However I scuffed up the powered coat and primed the the WD-1006-L/R.
