Conrads X-10 Build Log
Date: 9-2-2009
Number of Hours: 3.00
Manual Reference: 28-7 steps 1 to 4
Brief Description: Section 28, FWD FUSELAGE RIBS, BHDS, BOTTOM SKINS
Section 28, FWD FUSELAGE RIBS, BHDS, BOTTOM SKINS … Page 28-7, steps 1 to 4. Step1, I final drilled #30 all the hoes in common with the Firewall Bulkhead F-100A and the forward tabs of the F-1049 A,B,C in L/R. Step 2, clecoed the Forward Cabin FloorPanels F-1050 – L/R to the Fwd Fuselage Ribs F-1043A –L/R, Firewall Lower Channel and the F-1049 A,B,C in L/R. Then final drilled all #30 holes in common Step3, After unclecoing I final drilled #4- the nutplate hole and the #19 nutplate screw holes in the Forward Cabin FloorPanels F-1050 – L/R. As described in Figure 2. Step 4, I deburred all edges and final drilled all hoes in the F-1050 L/R Fwd Cabin Floor Panels. Dimpled the nutplate attachment holes and the dimpled the holes in the floor plate panel as shown in Figure 3. Time about 3 hours.
