5/29/2009 …. Section 23-2 Steps 3 and 4. Step 3 continued, THREADED ROD END INSTALLATION, I inserted the VA-169 Threaded Rod End into the Torque Tube end and riveted with MSP-42 pop rivets as shown in figure 2. Step 4, I first installed the AN316-6 Jam Nut onto the MD3614M Rod Eye End Bearing Bolt and then screwed this assembly into the VA-169 Threaded Rod End. The ides is to make the completed assembly 94 and 7/16 inches from the center eye hole of MD3614M Rod Eye End Bearing to the other MD3614M Rod Eye End Bearing. Time about 3 hours for both tubes.
