Conrads X-10 Build Log
Date:  1-4-2010
Number of Hours:  1.00
Manual Reference:  OP37- RV-10
Brief Description:  Section OP37- RV-10 WIRING HARNESS Page OP37-2, St
OP-37-2 I have decided to order the VAN’s RV-10 Wire Harness Kit. (Cost $635.00). It appears to be a good start. I have added a couple additional circuit breakers and purchased other not included items such as the ignition start key-switch.
Step 1 to 4, After inventorying the kit’s parts I followed the instructions and unrolled the harness in the fuselage to get a feeling of where the wires and connection occur.
Step 5, I drilled a .5 inch hole in the F-1001A Firewall as specified by the template and figure1 on page OP37-2.
Time about 1 hour.
Ignition Key Temp. Installed
