Conrads X-10 Build Log
Date:  11-26-2009
Number of Hours:  1.00
Manual Reference:  34 -7 Steps 1 to 5
Brief Description:  Section 34 BAGGAGE AREA … Page 34 -7 Steps 1 to 5
Step 1, I located then cleoed the F-1081 Left Baggage Cover to the F-1034C-L Fuselage Bulkhead and the just installed F-1058 Hinge Frame.
Step 2, Match-Drilled all the #30, #40 and #19 holes in common.
Step 3, After satisfied with the drilling I removed the F-1081 Left Baggage Cover, deburred,
removed the shinny alodine, cleaned with acetone and primed with DTM primer.
Step 4, I cut one layer of ½ inch Double Insulated thermal and sound protection insulation to fill the cavity between the Side Skin F-1070 and the F-1081 Left Baggage Cove. Placed using 3-M adhesive. After drying the part I began riveting the F-1081 Left Baggage Cover using the rivets called out for in figure 2.
Step 5, Also riveted the four nutplates as shown.
Time about 1 hour.
F-1081 Left Baggage Cover Installed
