Conrads X-10 Build Log
Date: 9-25-2009
Number of Hours: 2.00
Manual Reference: 29-12 Steps 1 to 5
Brief Description: Section 29, FUSELAGE SIDE SKINS …. Pages 29-12, St
Section 29, FUSELAGE SIDE SKINS …. Pages 29-12, Steps 1 to 5
Step 1, I added the 4 degree bend angle to the F-1042-L/R Bulkhead Side Channels.
Step 2, Created the F-1042E-L/R Gussets.
Step 3, I clecoed the F-1050-L/R Forward Cabin Panels to the foot areas. Then I cleoed the F-1002-L/R Fwd Fuselage Bulkhead, F-1040 –L/R, Upper and F-1041 Lower Fuse Channels, F-1042B-L/, F1042C Clips and F-1042E-L/R Gussets and the F-1088-L/R Forward Fuselage Ribs to the forward fuselage area.
Step 4, Arraigned all the Flange Angles along the F-1001A Firewall Bulkhead against the F-10123-L/R Fwd Fuse Longerons.
Step 5, Added by means of clecoing the F-1042B-L/R Clips to the removed F-1041-L/R Fuse Channels and F-1069-L/R Fwd Side Skins. Then I clecoed the forward side skins to the front structure of the X-10. Time about 2 hours
Left Side Fwd Side Structure
Right Side Fwd Side Structure
