Conrads X-10 Build Log
Date:  8-12-2009
Number of Hours:  5.00
Manual Reference:  26-7 Step 4
Brief Description:  Section 26 Mid. Fuselage Ribs and Bottom Skins. P
Section 26 Mid. Fuselage Ribs and Bottom Skins. Page 26-7 Step 4. Working on riveting the Bottom Skins F-1076 and F-1077 to the F-1034A Fuselage Bulkhead, Floor Stiffeners and Rib Flanges with AN426AD3-3.5, AN426AD3-4 and AN426AD3-4.5 flush rivets, being careful not to rivet the two very top and bottom rows as these are riveted later on. I am having trouble riveting the innermost rivets but I believe I can set the rivets using the “back rivet” method. If not I can always use “pop” rivets to do the job. Time about 5 hours because I am taking my time.
Bottom Skin F-1076 in riveting process
Working on riveting the Bottom Skins F-1076 to the F-1034A Fuselage Bulkhead,
Top Skin F-1077 after being Dimpled and Primed
