Conrads X-10 Build Log
Date:  4-14-2012
Number of Hours:  4.00
Manual Reference:  Oil Cooler Install
Brief Description:  Niagara Thermal 20006A Oil Cooler
04/15/2012
I ordered the Oil Cooler from Vans for the X-10. What I ordered was a Stewart-??? 20006A Oil cooler and what I received was a Niagara Thermal (as in Niagara Falls, N.Y. ) 20006A Oil Cooler with 13 individual cooling fins. I checked and it’s a very good brand and is legal for a production aircraft. The pressure drop at 60 PSI is less that 2 psi and at 20 psi it’s less than 0.5 psi. The install was pretty straight forward. I added some anti-seize to the threads of the AN823-8D and AN822-8D fitting to prevent “galling” because it’s soft aluminum.
Time about 2 hour to install and photograph.
Oil Cooler Installed onthe X-10 Firewall
Another View of the Niagara Thermal  20006A Oil Cooler
