Conrads X-10 Build Log
Date:  8-15-2010
Number of Hours:  8.00
Manual Reference:  SECTION 45-16
Brief Description:  Still fitting, sanding, Super-Fill and sanding and
SECTION 45-16
August 14th to 15th
Still fitting, sanding, Super-Fill and sanding and sanding the Doors and Fuselage to obtain that perfect fit. Also, I installed a key lock on both the Right and Left Doors just in front of the Door Handle. Seems to work fine but I was hoping for a flush outside Door fit but the door is not thick enough and I could not find a narrower lock set. However since I am using Van's stock supplied handle the two complemetn each other.
Time about 8 hrs.
Door Lock
Door Lock
Door Lock and Handle the Outside View
Door Latch Getting the Pop Rivets Filled Before Painting
