Lightning
Date:  1-17-2008
Number of Hours:  1.50
Manual Reference:  Section 1
Brief Description:  Fuselage Preparation III
Cut out the outlets of the fuselage NACA ventilation ducts and spent time sanding the fuselage flange.
I am thinking I will look for a Corvette painter when the time comes, but I will try to prepare it as best I can, so I am working on smoothing the flange all the way around.
Finished cutting out the starboard D-shaped hole at the wing root.
I bought some Sabre bits for my Rotozip. I think they were a bit better, but I still cannot cut more than about 3 inches before they overheat.
behind cockpit
behind cockpit
vertical stabilizer
vertical stabilizer
