Brief Description: Fabricate flute tube supports I
Measured and marked the position of the pivot hole and the lightening holes on the two pieces of aluminium channel supplied. Center punched and drilled the holes.
The pieces are about 1/2" longer than needed, but I decided not to shorten them until I am ready to fit them.
Also I have not cut the taper on the supports yet.
