Time to switch gears - since I'm going with a fuel injected engine, it requires a boost fuel pump which is typically installed near the fuel valve near the seats. Had to pay 6 Benjamins for this - ouch!!! Started the cover for pump assembly, drilled, riveted. Later will be running all the lines seen in the plans in pic 1. There is a bypass valve and filter included. The former is necessary in case the pump fails so fuel cam reroute around and still reach the engine (which will have an attached fuel pump).
