Serenity
Date:  10-29-2008
Number of Hours:  2.50
Brief Description:  Rudder pedal install, finish brake lines
Installed rudder pedals, then bolted on brake lines to brake pedal cylinders (for you builders using Bonaco or other type sleeved lines - note the nut fitting is compressing a steel flare, not aluminum, so torque values are significantly higher). Riveted most of the firewall recess holes - had to leave a few due to obstruction from the rotisserie frame.
Rudder pedals in place - note brake pedals just on pilot side. I decided not to install for passenger
Close up of brake cylinders - later I bundles these with tie wraps to ensure no rubbing
