Serenity
Date: 11-19-2006
Number of Hours: 2.00
Brief Description: elevator counterweights, bearings
Trimmed the 4 lead counterweights, but botched one, so need to reorder one from Van's. Right elevator weights were cut with the bandsaw, filed, then primed. I drilled out the holes a bit, then AN3 bolts, washers and nylock nuts attached (see grey weights left side of pic). An issue I don't like is that the nuts are to the outside and will be hidden by the fiberglass wing tip. I would rather be able to see the nuts on the other side where they would be visible during a walk-around inspection, but they probably wouldn't clear the HS. I will probably add another fastner, perhaps a screw, as per an RV Aviator article I read. Losing one of these weights in flight would be improbable, but the resultant flutter could be disasterous. Next, I screwed in all the bearing ends - Van's instructions recommend 13/16 inch from spar to bolt hole center with an allowance up to 7/8 inch. I went to 13/16, attached the elevator, and had some leading edge rub on the HS spar, so backing the rod end bearing out 1 turn was perfect. The jam nut was tighted by the 'Guttenteight' technique. I temporarily attached the elevators using allen wrenches (2 sticking up in the elevator/HS gap in pic 1, and closeup in pic 2), then fed in the bolts with taped over needle nose pliers. The elevtor swung freely, albeit 'nose'-weighted with the lead in the counterweight arm. Next, I need to attach the left elevator after I drill the HS center bushing hole into the right elevator control arm. I will use a sawed off 1/4 inch headphone plug as my drill bushing to protect the bearing, take off the elevator, then drill to size.
right elevator attached
blurry, but shows how to align with an Allen wrench prior to bolt insertion
Latest toy - birthday gift from the kids. Took several hours to run satellite feed, install
