Serenity
Date: 11-17-2006
Number of Hours: 3.00
Brief Description: Put together trim servo, finished right elevator T
Trim servo cover plate and supports clamped, drilled out, deburred. Screwed up platenuts on servo opening earlier (they were flat, whereas the cover plate attach holes are dimpled for #6 screws - I found the proper platenuts in the servo parts bag), so all 7 were drilled out, new platenuts with countersink openings installed. Servo was attached, tested with a 9 volt battery, everything put together, and installed for now. Last, the right elevator TE was riveted as per the left - came out nice. All is done now, except lead counterweights and to install onto the horizontal stabilizer.
Electric trim servo on cover plate
Dead straight, baby!
Just about done!
