Simple job today - make the little wedge pieces that fit under the splice plate and rivet them in place. I ground down a wedge shape on both sides of some angle scrap using the Delta sanding station. I then cut off the pieces with th eband saw, deburred, primed, and riveted them in.
Freaking cold - 3 propane burners running will only warm the garage a few degrees per half hour.
