Serenity
Date:  11-16-2009
Number of Hours:  2.50
Brief Description:  Canopy frame and hinge brackets
Disassembled, riveted splice plate, clecoed skin, fit back on fuse, re-taped after aligning, then partially drilled hinges, removed from plane and finished drilling. Then placed bushings, re-attached frame to fuselage. Hinges well except where it rubs on weather strip flanges - filing for next time.
Finished hinge mechanism - rest of frame will be next
Splice plate riveted
Had to raise fwd skin to reach in and drill
